lower control arms and cam bolts
can i put a set of after market front lowers on with cambolts already install. would they attach just like the stock ones or am i going to have to weld a washer on to the axle mounting bracket ?
Yes, you could install the the aftermarket arms with the cam bolts already installed. Assuming the arms are adjustble, welding the washers is better because you don't have to worry about the cams coming loose and moving.
