Low Speed Wobble Help
#21
And I thought i was the only one to have this prob. But I need new tires (33,000 on stock rubi tire) and rims( concrete culvert burried deep in the grass). I hope that when i change these it will stop. It will almost shake the steering wheel out of my hand at around 52-55 mph!
#22
Another item....... I just noticed your photo and it looks that you are running the center caps on the wheel.... just a note.... I had to take mine off and do some work on the them to ensure they fit correctly.... Remember....when they balance the wheel the center caps are not on the wheel...when you drive it...they are installed.... IF THEY ARE NOT PERFECTLY SEATED THEY WILL CAUSE THE WOBBLE. Hope it helps. Cujo
