low speed noise and T-case problems
Three days after I installed my front driveshaft(1350), a ARB front diff cover, a set of Crown brake lines and a Mopar hood lock I'm getting this funny noise from the front of the JK at very low speed(6-10mph) Less than 6mph no noise. Its like a fan barely hitting something. No vibes and it is not loud. It also goes away at speeds above 10mph. I'm not sure what might be causing this
, I do suspect the front driveshaft. I verified it and nothing seems to be in its way. I think I may have to grease it and see.
Something else happened today...my T-case shifter got disconnected
I don't think that this is related to noise mentioned above. So far I believe that the problem is in the console since I check the T-case cables underneath and found nothing wrong![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
I mention this in case anyone thinks that both my problems are related.
Any ideas?
Thanks!
![naw](https://www.jk-forum.com/forums/images/smilies/icon_naw.gif)
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
Any ideas?
Thanks!
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
Sponsoring Manufacturer
TeraFlex Rep
TeraFlex Rep
I would remove the front drive shaft and see if the noise changes or goes away. When you have the drive shaft off you can also turn the front transfer case output yoke by hand and see if you can feel anything besides "smooth". I have seen a case of shift linkage misalignment/bind that influenced the shift caller/fork for the mode selector causing it to rest in an "almost engaged" position. I don't think its your transfer case from what you have said but its easier to eliminate possibilities with the front drive shaft out.
![Fingers Crossed](https://www.jk-forum.com/forums/images/smilies/fingerscrossed.gif)
Thanks Mssbbmia
Anyone else want to add their 2 cents???
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
I have found the noise!!! It is coming from the front diff. Which makes sense since the noise did start right after installing my ARB diff cover. It is suspected that I need a thicker gasket. Oil level is fine.
Any suggestions?
Any suggestions?
