Low-cost / Free mods that should be done?
#891
Originally Posted by jeepsta
hi lift mount 6 dollars 2 u bolts from menards mount to roll bar put jack on then wing nuts done!!
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=286926"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=286927"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=286928"/>
I think that this solution is safer than most IMO.
#892
Originally Posted by bigf350sd
After playing around with where to mount my Mag-Light D cell flashlight, I ran across this thread WAYYY back near when it was started. I felt that mounting it to the seat mount, like several have done in this thread, would be a pain in my a$$, because it's very tight to get your hand down there to it when you have the doors closed, during winter riding, etc...and there's no way I could get it out to use, without opening the door. I decided to put my mounts up on the back side of the sound bar in my '07. I used 3-M heavy duty 2 sided tape as a "gasket" and then ran the screws in. Works great, and accessible ANY time, by anyone in the vehicle, front or back. It's been there about 6-7 months now, no problems.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=288457"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=288458"/>
#895
Originally Posted by dpowell5523
Do these come for a c-cell nag light? I have a stream light that is about the same size as a c-cell mag light.
#896
I said nag the first time. No, I don't plan on hanging my wife there. LOL
#897
I'm just using the Rugged Ridge ones, because they look factory, and come with a piece to cover that huge hole left in the door when you remove the mirrors. The passenger side mirror will have at least half of it blocked from view when the door is on, but a small blind spot stick on mirror in the lower outside corner does the trick for me, and just leaning slightly to the pass side allows you to see the whole thing pretty much. That may aggravate some people, but trust me, it's WAY better than going through the steps to remove and reinstall them every single time you want to pull the doors!
http://www.quadratec.com/products/13125_102.htm
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=288249"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=288250"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=288251"/>
Used these on my 08 and liked them, although a little hard to see out of he passenger one if you have the doors on.
#898
Originally Posted by CruSHeDJkUR
What if you have the heated mirrors? Would this still be an option.
#899
#900
Great call
Sell the stock spare with the other wheels and tires. Then buy a 5th wheel for another $40, and buy a used 35x12.50R15 off craigslist for the spare.
With the ESP on the JK, it can be problematic to try to rotate your spare with your other 4 tires unless you do it frequently. In other words, if you wait to rotate a brand new spare into the other 4 until you have 7-10k miles on the other 4, you can end up with ESP issues because your spare will be taller than the other tires (less treadwear).
So, most people do not rotate their spare.
It is so easy to find a common size like a 35x12.50R15 used, or that has 0 miles on it because it didn't get rotated in on a TJ/YJ/XJ or other rig at a cost of 1/2 or less of new, it makes good sense to go that route if you are doing a budget build.
I only eliminated it from my list because of the "budget build" theme.
Time to do some craigslist shopping when I change them out!
