Low-cost / Free mods that should be done?
#72
Definitely first Mod for the 2DR was to remove the rear seat what a waste this is totally useless............I actualy put it back in once for my grand daughter that is 2 yrs old and tiny as can be due to vehicle mix up.. that thing friggin killed me to use..needless to say i have a 2009 and 2010 rear seats for sale...LOL
#73
Location: Hawai'i, Miami , FL, Alaska, Tennesse..S America
#74
JeepSWAG
Sponsoring Manufacturer
I'll try to get all this posted in the first post:
Drilled Mirror mod https://www.jk-forum.com/forums/show...t=drill+mirros
Toss the backseat (2dr)
evap relocation http://www.jeepswag.com/jeep_jk_evap...tion/index.htm
Smoked tail lights
Grill mod, with gutter guard mesh wire and black paint...
Zip tie mod for hood flutter
center mirror - Flip it upside down for a better view
zip tie the transfer case shifter cable.
side markers turned into blinkers mod. https://www.jk-forum.com/forums/show...rker-light-mod
tucking the front seat belt straps into the plastic molding to stop the flapping noise when the doors are off mod.
remove the torx bolts from the door hinges and "toss" them.
Freedom Top Rubber Boot screw mod
Cut the cup holder insert in half https://www.jk-forum.com/forums/show...Cup-holder-mod
Rear window screen https://www.jk-forum.com/forums/show...-window-screen
Muffler Delete
HID Conversion $55
Superior Axle Tube Seals $70
Extending axle breather tubes
tailgate gas strut to hold it open http://www.jeepswag.com/jeep_jk_tail...lder/index.htm
fender chop
stock stubby front bumper
e-disco flip https://www.jk-forum.com/forums/show...rker-light-mod
drill out the stock plastic bolts that hold the shifter boot assembly and replace with stainless steel fasteners
Pull the carpet and drain plugs- no instructions needed
Put weater stripping around the rear "storage" area under the hatch in the trunk to keep water out.*
Remove lower air dam
Extend rear axle breather- write up on project-jk
Extend brake line brackets
1" rear extended bumpstop with $1 used hocky puck on each side
trim pinch seam in rear fender well
re-locate rear bumper up 1" or paint rear edge pinch seam flat black
remove the spring under the hood to eliminate the hood flutter
Painting the inside of the top with black bedliner was another great mod for around $20- $30.
Maglite mount to side of driver side seat mod was another great one for around $5 or so.
The garage door opener in upper A-Pilar cover
Copper antiseize on all the spark plug threads.
Hot wiper fluid mod for de-icing windshield
Headrest Spring Removal to allow rear headrests to lay back
Hose Clamped Front & Rear Differential Breather https://www.jk-forum.com/forums/show...-be-done/page8
I'd like to welcome everybody to my sandbox. I have tried to develop kits that are in the sub $100 range and I've got a few to offer:
JeepSWAG mods, under $100
Hi-Lift Jack Mount Kit behind 4-Door rear roll bar $80 LINK
Compressor mount in engine bay $50 LINK
Hawk Brake Pads under $65 per axle LINK
Evap Canister Relocation Kit $80 LINK
Hard Top Saver Kit $30 LINK
Hood Strut Kit $80 LINK
Steering Stabilizer Relocation Kit $45 LINK
Tailgate Strut Kit $80 LINK
2 Gallon Engine Bay mount kit $45 LINK
Anti-Hood Flutter Kit $9 LINK
Smoked tail lights
Muffler Delete
HID Conversion $55
fender chop
#76
Smoked tail lights
Muffler Delete
HID Conversion $55
fender chop
Smoked tail lights
Muffler Delete
HID Conversion $55
fender chop
#77
Awesome, useful thread!!
Don't forget the "under e-brake storage" mod. There are a few different ones on here. But here's mine using the left over piece of rear floor liner.
https://www.jk-forum.com/forums/show...ke-storage-mod
#78
Here's my $1.50 shovel/jack mounting job. Just weld two 5 inch long x 3/4 inch bolts to your tow hooks. Use flat rubber between hooks & jack & radiator hose under shovel blade to keep things tight & rattle free. And $1.00 stubby stock bumper mod. Did the rear too.
Rear stubby mod
#80
