Low-cost / Free mods that should be done?
Old 01-22-2015, 11:47 AM
  #4301
medic_23387's Avatar
Done these over a year ago but never posted it. I'm stingy lol. Homemade grill $30. Skull snorkel topper $20
ID:	593201   Click image for larger version
Old 01-23-2015, 02:21 PM
  #4302
Phottomatt's Avatar
Originally Posted by patmasterflash
I like your shift knobs. I just took mine off and had no problem with the transfer case. I used vice grips below the knob and a hammer to tap it off. The shift knob was a different story. I tried every technique listed but that MF'er was welded on. I ended up using a saw to cut the knob into pieces. I made a ridiculous mess of plastic, blood and chipped paint but I got that SOB off! I don't recommend my method.
If you pry the little cap off the top of the knob there is a sping clip in there.
Old 01-26-2015, 09:23 AM
  #4303
DBA07JK's Avatar
Shifter extention. ......
Hello ..fist post on this thread. .just thought i would share 1 of my low cost mods. .@ $30 bucks 2 pool balls & one 3 inch extension. .dilled & tap both pool balls ..cut the tips off of both shifters. .the transmission shifter i drilled &tapped & the transfer case shifter i die cut ..to me it is a much better feel. .
Old 01-26-2015, 04:37 PM
  #4304
PANGMAN's Avatar
Excuse my ignorance, but what are the two white cables going from the front of the Jeep to the top window corners for? I've seen it on a couple of Jeeps and was wondering what they do?
Old 01-26-2015, 05:10 PM
  #4305
JK505's Avatar
They're called limb risers. They help deflect tree branches on narrow trials. The branch rides up the cable and over the jeep instead of into the windshield and down the side.
Old 01-26-2015, 05:25 PM
  #4306
muddyman184's Avatar
Is that your fog lights mounted in your grill? Likes B.A.
Old 01-26-2015, 05:45 PM
  #4307
cptjon's Avatar
grill mod definitely helps keep bugs off of the radiator
Old 01-27-2015, 05:26 PM
  #4308
mr.brav90's Avatar
Originally Posted by DBA07JK
Shifter extention. ...... Hello ..fist post on this thread. .just thought i would share 1 of my low cost mods. .@ $30 bucks 2 pool balls & one 3 inch extension. .dilled & tap both pool balls ..cut the tips off of both shifters. .the transmission shifter i drilled &tapped & the transfer case shifter i die cut ..to me it is a much better feel. . <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=593788"/>
I would like to see a better lit picture.
Old 01-27-2015, 05:41 PM
  #4309
DBA07JK's Avatar
Here u go. .the pics look better on my phone. .sorry
Old 01-29-2015, 02:07 PM
  #4310
MDRoots's Avatar
Originally Posted by stgillen
Trying green out
Looking into doing this, did you cook them and put the strips inside or just stuck on the outside? Also how do they look in the daytime?
Quick Reply: Low-cost / Free mods that should be done?
