Low-cost / Free mods that should be done?
#4152
#4153
#4155
But, these look like they have the LEDs around the outside and a regular bulb in the center ... which would solve the problem. Is that correct?
#4156
The problem I've found with LEDs is they don't run hot and during the winter won't melt the ice that can build-up on the headlights/foglights/extra lights. I've just stuck with regular lights because of that.
#4157
#4158
I would imagine the law has a specifier as to intent (such as illegal drugs or weapons). For example, in Ohio, the law prohibits designing, building, constructing, fabricating, modifying, or altering a vehicle to create or add a hidden compartment with the intent to facilitate the unlawful concealment or transportation of a controlled substance, prohibit operating, possessing, or using a vehicle with a hidden compartment with knowledge that the hidden compartment is used or intended to be used to facilitate the unlawful concealment or transportation of a controlled substance.
I would question if this would even constitute a hidden compartment since it's an existing compartment that you are making bigger.
#4159
#4160
Warrior Products makes a lockable TRUNK storage compartment
Lockable Storage Trunk | Warrior Products
