Low-cost / Free mods that should be done?
Old 10-06-2013, 09:59 PM
  #3781
09jku's Avatar
Originally Posted by deepjeep13
Any body do some somewhat cheap exhaust? I like how some guys got it dumped right after the rear end?
I jst took the muffler off and called it good. I like the sound!
Old 10-06-2013, 10:09 PM
  #3782
redlinin616's Avatar
$65 sounds perfect!
Old 10-06-2013, 11:24 PM
  #3783
MarineArmyJeeper's Avatar
Originally Posted by BlkJeep
Sprayed fenders with bedliner with a personal touch.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=495446"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=495447"/>
I like the added touch on the lights..
Old 10-07-2013, 12:18 AM
  #3784
deepjeep13's Avatar
Hows the eco without? Millage any different? Back pressure etc
Old 10-07-2013, 12:19 AM
  #3785
deepjeep13's Avatar
Originally Posted by redlinin616
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=503198"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=503199"/> $65 sounds perfect!
Looks good, any change it may get hung up?
Old 10-07-2013, 01:22 AM
  #3786
Rico's Avatar
Originally Posted by sdhyt3
I'm digging your bumper. Who makes that? Or is a modified MW3/Mopar piece?
Yup ..modified my bumper by adding the bullbar...drilled it out and bolted.
Old 10-07-2013, 01:25 AM
  #3787
09jku's Avatar
No Ecco. Mileage is better however I don't know the exact numbers it been to long since I did it. To me it no louder than a good set of mufflers on a v8. Yes it's a bit more bumble bee ish but not like a rice burner, I like to think it sounds like a jeep lol but because it's jst a bolt on and off you can always jst put it back on if u don't like it. I tossed mine! That damn thing weighs like 40 lbs that will save some gas right there. As far as back pressure I didn't see a difference, having 2 cats pretty much keeps the pressure there.
Old 10-07-2013, 03:34 AM
  #3788
Coach24's Avatar
Originally Posted by Matthewd5
Great shovel mount, I was thinking of something very similar, do you feel like the shovel handles strength was compromised at all?
Matthew
Nothing noticeable but I haven't actually used the shovel yet. It's made from ash so I don't think its strength is significantly compromised. If it breaks, it's cheap enough to get another one. I think it was 10 or 11 bucks. A new handle costs more. I looked at the nicer ones but spending $30-40 seems crazy. Plus if someone steals it, I can live with that and then I can engineer something with a lock. lol
After I ran the pilot hole, I should have drilled out the back with the 3/8" bit first to avoid splintering but couldn't be bothered.
Since it's a short handle, I doubt there would be times where I'd be lifting dirt holding the shaft above the hole with both hands. Had it been a longer tapered shaft, I might reconsider drilling that hole and make a clamp instead.
Old 10-07-2013, 12:54 PM
  #3789
deepjeep13's Avatar
I have eco but couldnt imagin it being to far off.
I was thinking of getting a magnaflow and taking my exhaust off an just go from there. Right now im hug up on a winch .. To buy or not to buy that is the question!
Old 10-07-2013, 03:14 PM
  #3790
Matthewd5's Avatar
Originally Posted by Coach24
Nothing noticeable but I haven't actually used the shovel yet. It's made from ash so I don't think its strength is significantly compromised. If it breaks, it's cheap enough to get another one. I think it was 10 or 11 bucks. A new handle costs more. I looked at the nicer ones but spending $30-40 seems crazy. Plus if someone steals it, I can live with that and then I can engineer something with a lock. lol After I ran the pilot hole, I should have drilled out the back with the 3/8" bit first to avoid splintering but couldn't be bothered. Since it's a short handle, I doubt there would be times where I'd be lifting dirt holding the shaft above the hole with both hands. Had it been a longer tapered shaft, I might reconsider drilling that hole and make a clamp instead.
I'm going by tractor supply soon, last time I was in there they had some really nice wooden handle shovels pretty cheap
Matthew
Sent from my iPad using JK-Forum
Quick Reply: Low-cost / Free mods that should be done?
