Low-cost / Free mods that should be done?
#3651
I have the same issue and have been told that I need these.
Jeep Wrangler JK ('07&Newer) 4-Door Hinge Bushing with Installation Tool Set - Black
Anyone else replaced the bushings?
#3652
I take my doors off and on a lot, and these are great. Look around, I paid quite a bit less than that, although mine didn't come with the installation tool, so maybe that's the difference. Most of the old bushings came out fairly easily, but a couple were a real pain, so maybe it's worth it for the tool.
http://blackmagicbrakes.com/site/mob...Jeep_Co-Op.php
#3655
I did mine with tin snips & a utlity knife. When done I used a belt sander to smooth/even the edges. Kind of melts the plastic to give it a finished edge.
TAKE YOUR LINES OUT
When I removed my liners, there was mud & road grime on the tops of the liner & on the areas of the Jeep the liner covers that CAN'T be washed with the liners on
TAKE YOUR LINES OUT
#3658
Day star hinges cheap and affective and easy to install you can buy them on any jeep website uses factory clips just replaces loose rubber tat causes the hood flutter with stronger tighter rubber... And comes with all the hardware thst you'll need
#3660
