Low-cost / Free mods that should be done?
#2261
I literally just pulled off stock knob. Drilled a hole in bottom of beer tap and slammed it on shifter. Done
#2262
The problem with those antenna is that they have a plastic base. I went thru several of them on my Firebird before i simply gave up. The rubber antenna itself will flex, but the hard plastic base will break. Forget to remove it once before you go thru the drive thru carwash and its toast. And any tree lined trail will take it out too.
#2263
#2264
#2265
[QUOTE=xerofall;3402096]
I just cut my stock one down. I put a metal bead from my wife's necklace kit on the tip to mimic the stock tip, then painted the thing with that rubber spray stuff.
I love it
Does it still work???? Has it reduced your reception????
I love it
#2266
#2267
These LED backup lights were plug-and-play on my 2013 JKUR:
http://item.mobileweb.ebay.com/viewi...d=120946602439
Worth every penny...
#2268
2pcs 3157 3156 White CREE Q5 5W LED 12 5050 SMD Backup Light Bulbs w Lens | eBay
#2269
