Low-cost / Free mods that should be done?
#1971
Originally Posted by Cobb_Sahara
Dynomax 17263 ultra flo SS. From Amazon for about $90 after I included 2 clamps.
#1973
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=394792"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=394793"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=394794"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=394795"/>
Those pics just sold it for me i think.
With your sound... Do you get any drone? How's the lower RPM range for you? See any gain in mpg? Lol. Overall, how do you like it? Worth the $73?
#1974
#1976
Took me a few minutes to tell, but i like how you reused the old pipe. I was worried I'd have to buy a new exit. I really like how you have it dumping behindish the axle.
#1977
Originally Posted by Delux2769
Which dynomax did y'all put in? How much was the cost of it?
#1979
When doors-off driving, I've had a problem with the rear carpeting coming loose and nearly blowing away, but took care of it with two 1/4-20 bolts. On my 2008 4-door, there's a 6mm hole on the inside wall, just behind each rear door latch. I drilled a hole through the carpet over these holes, and shoved/screwed the bolts in (it was a tight fit, but widening the holes wasn't necessary in my case). I secured each bolt with a locking washer and nut, then tucked the top corner of the carpet back in place. That location was the weakest link - once a strong highway gale pulled it loose, the rest of the carpet would inflate out of its seams. With those two bolts in place, it's not going anywhere - not bad for $2!
#1980
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=395014"/>
