Low-cost / Free mods that should be done?
#1681
Originally Posted by JoeRif
So I may have missed if this happened to anyone else in the previous 900 pages, but im attempting to do the grille mod, and the screws in my grille frame are plastic, as well as the plug anchors ~ and the damn screws don't back out! They spin like crazy but no progress. Anyone else experience this and what did you do to get them out? For such a "simple and inexpensive" project, I can't even get started because of this crappy Chrysler decision to use cheap a## plastic hardware
#1682
I used a the corner of a putty knife between the plug and the screw to work it up. Anything flat like that will work. The threads on the plastic screws are pretty much worthless.
#1683
#1684
I used a screw driver and pried up the screws. Mine do the same thing bc I've taken the grille off so many times.
#1686
#1690
This should keep you busy
LINK-> https://www.jk-forum.com/forums/jk-w...al-2dr-246787/ $15
here are breather hoses on both axles, the transfer case, and auto transmission. On manual transmission there is a breather under the shift boot (at least I have seen a picture of a 3.8L there). They are there to let gases escape with changing temperature. If you lift your Jeep you may need to extend your breathers on your axles so they don't come off when flexing. Another reason to extend your breather hoses is to raise them up where they are less likely to ingest water and contaminate your oil. It's something everyone with a snorkel, or who plays in water should do.
http://www.youtube.com/watch?v=PbxL2m6CUhw]Breather Hose Locations 2012 Manual JK Wrangler - YouTube LINK-> https://www.jk-forum.com/forums/stoc...-cover-247165/ $25
http://www.youtube.com/watch?v=TYmnuMa8ofM]303 Fabric Guard - YouTube LINK-> https://www.jk-forum.com/forums/jk-s...f-sack-239689/ $40
QUICK RELEASE SIDE MIRRORS - $35
Get 2 shoulder pads at wal-mart (made by "custom accessories"). They are about 8" long. I put them down by where the belt feeds out on each side, and it stopped the flapping cold. The custom accessory ones are nice because they let the belts spool back in. You won't even know they are on once installed. Not all brands of shoulder pad will work. I tried another type from auto-zone that wouldn't let it go back in when you unhooked the seat-belt, so I returned those.
LINK-> https://www.jk-forum.com/forums/jk-w...12-2dr-238728/
LINK-> https://www.jk-forum.com/forums/jk-s...hreads-238739/ -$200 with all the supplies and sprayed. It's cheap compaired to the $1500 you could pay for Line-X. Overall the best mod I have done so I will add it.
MALL CRAWL GROCERY CARGO NET $10
I got this net show below at Lowes. Secure Tite 15" x 30" Mini Cargo Net
Item #: 317632 | Model #: 61444. It works good sometimes I wish the netting was a bit closer.
LINK-> NO DRILL CB MOUNT ON FOOTMAN LOOP - $10
People have got this to work with full sized (Cobra 29) radios too. That's a Uniden 520XL shown. A full cb set-up cost $150+. If your just looking into it I would check out this link-> https://www.jk-forum.com/forums/jk-c...-guide-246403/
LOCKING LUG NUT ON SPARE - $20
I don't do my driving wheels, but I do put a lock on the back tire. The most secure locking lugs are made by Gorilla.
Gorilla Automotive 71481NB5 - Gorilla High Security Wheel Lock Set in Chrome for Jeep® Vehicles - Quadratec
SPRAY PAINT EXAUST & TOUCH UPS - $8
Take a scotch bright pad then scuff your exaust up to prep, then Paint. You can also touch up any other areas that need it. Rustoleum High Heat Ultra spray paint is nice because it doesn't require primer much like bedliner. It also won't burn off and smell nasty.
SET THE CLOCK
Oh your clock is on the right time. Well then disregaurd this until next month when it is off 5 minutes
I condensed DesertJeepin's great thread on the link above. Here are 2 I would recommend doing the most.EXTEND ZIPPERS - FREE-ISH
You can take a small peice of paracord and make it into a loop. Then extend your zippers by going through the zipper hole and looping the cord on itself.
These will not vibrate at interstate speeds. They take about a minute to put on or take off. if you think these look too much like a mod. I have heard that Harley (motorcycle) mirrors are a good option (won't vibrate)
This is all the parts and tools you will need for one side
Hand Release Mirror Parts
NOTE:: I got the mirrors at Advanced Auto ($10 each) the rest I got at Home Depot for about $15 so both mirrors for about $35
Putting it all together
STOP SEATBELT FLAPPING $9This is all the parts and tools you will need for one side
- Stainless Steel Eyebolt with Nut 3/8" X 6 - This was hanging on the wall
- Wing Nut 3/8" - 16 thread - Stainless Steal - This was hanging up close to the eyebolt nut
- Bonded Sealing Washer 3/8" Galvanized - 2 per each mirror - Located in the boxes - It is sort of warped like a cone - one side is rubber the other is metal.
- Spacer Nylon 3/8" X 1" - 2 per each mirror, so 4 if your making 2 - Located in the boxes labeled spacers
- 3/8" Flat Washer - Should be just a bit smaller than 1" in diameter - 2 per each mirror
- Put a flat washer on the eyebolt nut
- Put 2 of the nylon spacers on
- Put another flat washer on
- Put the stainless steal nut that comes with the eyebolt on just hand tight
- Put the mirror harness around the spacers. You can remove the black plastic liner. Make sure you have it pointing the right way for the side your putting it on.
- Alternate tighting the 2 nuts you just put on until it isn't going to move at all- It takes a 12mm and 14mm wrench
- Put on one of the Bonded Sealing Washers with the rubber pointing down.
- Put the assembly onto the hinge
- Put another Bonded Sealing Washer on there with the rubber side faceing up.
- Put on the wing nut and tighten it down as well as you can with your hands.
- Adjust the mirror
SET THE CLOCK
SETTING CLOCK ON THE I'M TOO CHEAP TO UPGRADE RADIO
1) Hold down the time button until the hours flash
2) Set the time with the station tuner knob on the right side (across from the volume).
3) Push in the tuner knob to switch to minutes. They will start to flash
4) Set the time with the tuner knob, and click when done.
LINK-> https://www.jk-forum.com/forums/stoc...isable-228859/ -FREE1) Hold down the time button until the hours flash
Remove Seat Belt Reminder Chime
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the
ON/RUN or START position. Chrysler Group LLC does
not recommend deactivating BeltAlert.
1. Turn the ignition switch to the OFF position, and
buckle the driver’s seat belt.
2. Turn the ignition switch to the ON/RUN position (do
not start the engine), and wait for the Seat Belt Reminder
Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver’s seat belt at least three
times within 10 seconds, ending with the seat belt fastened.
__________________________________________________ ____
Remote Key Unlock All On First Press
1. Press and hold the LOCK button on a programmed
RKE transmitter.
2. Continue to hold the RKE transmitter LOCK button
for at least four seconds, but not longer than 10 seconds,
then press and hold the RKE transmitter UNLOCK
button.
3. Release both buttons at the same time.
4. Test this feature while outside of the vehicle by
pressing the LOCK/UNLOCK button on the RKE transmitter.
NOTE:Pressing the RKE transmitter LOCK button
while you are inside of the vehicle will activate the
Vehicle Security Alarm. Opening a door with the Vehicle
Security Alarm activated will cause the alarm to sound.
Press the RKE transmitter UNLOCK button to deactivate
the Vehicle Security Alarm.
5. If the desired programming was not achieved or to
reactivate this feature, repeat the above steps.
NOTE:Pressing the LOCK button on the RKE transmitter
while you are inside the vehicle will activate the
Press the UNLOCK button to deactivate the Vehicle
Security Alarm
Light to turn off.
RKE transmitter.
button.
Security Alarm
Alextorello (09-24-2018)
