Low-cost / Free mods that should be done?
Old 08-01-2012, 04:39 AM
  #1551
n3tfury's Avatar
Originally Posted by ScubaDude
That seems like a bit of a risky situation. You would be risking your jeep (and maybe your life) on a home made design...
Some things are not meant to be DUI. This is one of them.
Old 08-01-2012, 04:53 AM
  #1552
TYDFAN's Avatar
I agree, if you are looking for a cheaper option than a winch, use a hi-lift, a tree saver and a QUALITY strap with loops. Not the cheap shit with the metal hooks that kill people
-Nathan
Old 08-01-2012, 07:06 AM
  #1553
Rubitron27's Avatar
Bedlined grill, door hinges and are by windshield All for $11
Then recut fenders for $0
Old 08-01-2012, 07:52 AM
  #1554
kaptkrappy's Avatar
Originally Posted by Devildoc
I was researching things like the " Pull Pal " as a self winching recovery tool. Has anyone made one of these themselves? I'm thinking I have a good idea on a cheap build or mod. I was just wondering if it's been done and if they have pictures to bounce a few ideas off?
Boy, they are "proud of those" = $$
Great idea for when you are wheeling alone (which we all know is a bad idea) and there is nothing to attach your winch cable to like in the desert or on the beach.
I would, like some have said on this topic allready, be careful if you are going to rig one up. Lots of things can go bad when using a winch, and stay away for using chains and hooks.
Old 08-01-2012, 08:04 AM
  #1555
KY JK's Avatar
Originally Posted by Jeek.OlllllllO
Have ya tried to relocate your license plate?
Yup... E-Z!!!
Name:	Jeep plate2.jpg
ID:	348361Click image for larger version
ID:	348365Click image for larger version
Old 08-01-2012, 08:16 AM
  #1556
IR Tools's Avatar
You're assuming that the company has actually done the analysis required to ensure that the design has a sufficient safety factor for all forseeable uses. I suspect that is probably not the case and it is a very small company or individual that came up with a cool idea that is produced on a very small scale. Seems like you could come up with a design that uses an adequate size and grade of steel and fasteners and it would be just as safe. Just my .02
Old 08-01-2012, 09:22 AM
  #1557
kaptkrappy's Avatar
I was just thinking, (can you smell the smoke) what about a Danforth anchor ?
It would plow in soft ground and give you that little extra pull to get out of alot of situations (if you're not buried up to axles).
Old 08-01-2012, 09:48 AM
  #1558
TYDFAN's Avatar
Originally Posted by KY JK
Yup... E-Z!!!
From what I gather, you notched the cap for the cord and bolted the braket to the cap?????
-Nathan
Old 08-01-2012, 10:20 AM
  #1559
JeepersKreepers's Avatar
Yup... E-Z!!!
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=348361"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=348362"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=348365"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=348367"/>
How did you do that??
Old 08-01-2012, 10:25 AM
  #1560
KY JK's Avatar
https://www.jk-forum.com/forums/modi...-plate-242243/
It took longer for the glue to dry and run the wires than it did cutting up the bracket. Made a plug for the hole in the back where the plate holder used to be.
Yes, bolted it directly to the wheel center cap, drilled a small hole on the side for the wires and ran through the wheel.
Quick Reply: Low-cost / Free mods that should be done?
