Low-cost / Free mods that should be done?
#1551
#1552
-Nathan
#1554
I was researching things like the " Pull Pal " as a self winching recovery tool. Has anyone made one of these themselves? I'm thinking I have a good idea on a cheap build or mod. I was just wondering if it's been done and if they have pictures to bounce a few ideas off?
Great idea for when you are wheeling alone (which we all know is a bad idea) and there is nothing to attach your winch cable to like in the desert or on the beach.
I would, like some have said on this topic allready, be careful if you are going to rig one up. Lots of things can go bad when using a winch, and stay away for using chains and hooks.
#1556
You're assuming that the company has actually done the analysis required to ensure that the design has a sufficient safety factor for all forseeable uses. I suspect that is probably not the case and it is a very small company or individual that came up with a cool idea that is produced on a very small scale. Seems like you could come up with a design that uses an adequate size and grade of steel and fasteners and it would be just as safe. Just my .02
#1557
It would plow in soft ground and give you that little extra pull to get out of alot of situations (if you're not buried up to axles).
#1559
Originally Posted by KY JK
Yup... E-Z!!!
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=348361"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=348362"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=348365"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=348367"/>
#1560
https://www.jk-forum.com/forums/modi...-plate-242243/
It took longer for the glue to dry and run the wires than it did cutting up the bracket. Made a plug for the hole in the back where the plate holder used to be.
Yes, bolted it directly to the wheel center cap, drilled a small hole on the side for the wires and ran through the wheel.
