Loud squeaking coming from front wheels, please help
Old 04-11-2013, 08:08 PM
fredrok's Avatar
If it's worse when you brake, low pad "squealer" . But the fact that you said it's worse after washing is odd. Likely just worn pads (wear indicator).
Old 04-11-2013, 08:14 PM
Josephrobby's Avatar
Originally Posted by fredrok
If it's worse when you brake, low pad "squealer". But the fact that you said it's worse after washing is odd. Likely just worn pads.
Thanks for the feedback, going to head down to a brakes place tomorrow and have them take a look at it
Old 04-12-2013, 04:29 PM
Bump bump bump
Old 04-12-2013, 04:32 PM
Jeremy072288's Avatar
When does the noise happen? Over bumps? Pressing the brakes? On turns?
Old 04-12-2013, 04:39 PM
Just at slow speeds.. Less than 20. Once I'm past it the noise is gone. Plus it doesn't seem to worsen when using the breaks at all
Old 04-12-2013, 04:51 PM
eclipse3319's Avatar
Possible wheel bearing?
Old 04-12-2013, 04:54 PM
That's what I was thinking. Sprayed some silicone spray hoping it need some lube maybe or it was some sand. Doesn't seem to be that
Old 04-13-2013, 04:58 AM
It could be a lot of things. I had squeaking and it ended up having to do with one of my brake pads. My buddy had a loud squeak and I think it had to do with a control arm bushing. I'd check all bushing and see if there is any dry rot or signs of wear. And if you don't see any buy a couple cans of wd and spray that bitch down lol jk
Old 04-13-2013, 10:40 AM
So should I just take it to a local brake place?
Old 04-13-2013, 10:44 AM
robsjeep9's Avatar
What about the ball joints? Need greasing I was getting a noise like that ended up being just the ball joints ..,,, good luck
Quick Reply: Loud squeaking coming from front wheels, please help
