loud snapping sound in front end after lift.
Old 04-27-2011, 10:13 AM
  #21
Former Vendor
Rock Krawler Suspension's Avatar
Try disconnecting the sway bar links and isolating them from the equation. Then go from there! Good luck with your diagnosis.
RK
Old 04-27-2011, 10:18 AM
  #22
Jknockers's Avatar
Originally Posted by Monte417
I just checked the drivers side coils and it looks like I have about an inch on space bewteen the coil and the sway bar. Is that not enough? What do you have?
I would say 3/4 inch of space between driver coil and end of sway bar,,, I would isolate or put something between the bar end and coil or some how move the sway bar away from coil and then do a check to see if it has gone away,,,,
Old 04-27-2011, 10:50 AM
  #23
jacksonbmx23's Avatar
Check the disconnects again cuz mine use to do that to and once I tightened them down it stopped
Old 04-27-2011, 12:28 PM
  #24
Monte417's Avatar
RK
I will try both of these thanks
Old 04-28-2011, 01:51 AM
  #25
Trauma's Avatar
I am so worried these noises are causing damage...
Old 04-28-2011, 03:33 AM
  #26
Jknockers's Avatar
PLease don't worry,, There are lots of replacement parts out there,,, think of it as a chance to upgrade
Old 04-28-2011, 03:52 AM
  #27
Night Hawk's Avatar
Do you have pics? Mine really is no where near the frame
I found my noise. The coil spring was turned and leaning in.
Old 04-28-2011, 04:58 AM
  #28
Trauma's Avatar
Which?
I noticed this morning my front springs fell out of the notches that hold them at the bottom but its still on the perch.
Old 04-28-2011, 05:36 AM
  #29
Monte417's Avatar
what was you coil hitting your sway bar
Old 04-28-2011, 06:39 PM
  #30
Night Hawk's Avatar
It was hitting the frame right behind the spring. I turned the spring and it now has plenty of space. It wasn't in the perch.
Quick Reply: loud snapping sound in front end after lift.
