loud snapping sound in front end after lift.
I can't use search on my phone so I had to make a new thread.
Anyway I still have this problem and cannot figure it out.
Only when the brakes are applied, I get a loud snap in the from end.that sounds like two pieces of metal striking eachother and seems to originate at the driver side front tire but I could be wrong.
It does not happen all the time, usually it doesn't happen but I can get it.to happen if I pull into a parking spot quickly and hit the brakes.
I retorqued all control arms/shocks/sway bar. I don't see an issue with the brakes...
The only thing I need to re torque is the upper trackbar. It is tight but was not done with tire on the ground. I don't see why this would cause it though.
Front trackbar, shocks, springs. Rear bracket. And discos.
The only pushing would be the trackbar...il double check but it should all be fine...
