Loud Clattering Noise When Under Stress
Not sure if this is common, but whenever my 08 JKU is under stress (low rpm and working hard) there is a loud ticking/clattering sound from under the engine.
For example climbing up a steep rock or pulling out of a mud hole.
Is this common or do I have something loose?
However if its REALLY loud could mean you have something broken or worn out.
No, no problems in 4 low just in 2wd and 4hi when the rpms are low and stressing.
It is loud, kinda sounds like...
http://www.youtube.com/watch?v=JHFXG3r_0B8
but a little faster... I will try to post an actual video of what is does this weekend.
I have the same problem. Does it occur when you are trying to accelerate from a slow speed in a higher gear?
I figured mine was broken welds on my heat shield but I would like to hear other opinions.
