Lost Oil Pressure
Lost Oil Pressure
Hope someone can help me out. I have a 2017 Jeep JKU that I was off-roading. While on the trail I lost oil pressure. It dropped to zero. Then a bad Knock came from the engine. I towed the Jeep home and let sit. Started it up and had better oil pressure and then it started to drop and Knock again. I checked the oil and it looks good. What could be causing the issue. I took to the local Jeep Dealer and they don't want to look at it because they say I was offroading. Not sure if this is something I can fix with new oil pump or sensor. Or is there something more. Any advise would be great.
Lost Oil Pressure
Well, the knock probably indicates a Bearing is damaged.. A question why did you tell the dealer you were off roading? What mods do you have on ? Big Lift, Tires etc.. You stated you have a 2017 .. IMO the oil pump will not correct the knock...check the warranty and if the local dealer is not the selling dealer get back to your selling dealer- if the local is the selling, just off roading should not be reason not to honor the warranty;JEEP advertises showing them off road. the dealer should inspect and diagnose then determine if it is a failure that is or is not covered by warranty.
Oil Presure, Knock
Sounds like as spun bearing in the old days you could remove the spark wires one at a time if the knock stopped that was the rod with the spun bearing this would cause the pressure to drop also
I agree. Push the dealer harder. If they don't respond then start a case with higher ups. They advertise our jeeps for off-road, so they can't deny your claim unless it is ridiculously obvious abuse. Why did you even tell them you were off-roading? Just clean it up and take it to the dealer.
