Loose Trackbar bolts? Anyone change bolts to a larger size?
The bolts on my Teraflex track bar keep loosening up. The Teraflex bar uses the stock bolts. I thought I remembered reading that someone had used some larger bolts that more closely match the ID of the Teraflex bars. What size bolts? Do I need to drill the factory brackets?
Thanks,
Thanks,
Thanks,
Thanks,
track bars will loosen up, its just how it is.. use locktight, and check them every other week or once a month.... Mine comes loose on occasion too
i put a few welds on the nut to keep it from moving, then i torqued it down nice and tight, and i'll keep an eye on it, if retightening it gets old, i'll put a tack weld on the bolt head too. but so far so good
