Loose trac bar and stabilizer bars?
I have been hearing some clanking noises every now and then so I decide to put the Jeep on the lift to see what was going on. Is there suppose to be this much play in the trac bar and stabilizer bar?(not sure if that the correct term for those bars).
Here are the videos.
http://www.youtube.com/watch?v=wNAjzmr0Ing
http://www.youtube.com/watch?v=LWeM458O7Vw
Are the joints going bad or is this normal? Thanks in advance.
Jack up the front end, grab the tire at the 3 and 9 position give the tire a wiggle and look for play in the steering. It is normal for those parts to twist bit there should be no play from side to side..
