Looking to upgrade my 2012 jk 2 door for improved trail capabilities...
The downside to not adding rear traction with the gears is just paying the labor twice. Nothing at all wrong with doing it that way if the budget at regear time doesn't allow for the extra thousand, (or whatever the price is for the traction device you choose). Just makes more sense to do it all at the same time if you can.
Or should I wait till front one dies naturally?
I want to get this done and be relatively safe for a while so I can go wheel it on harder trails and be able to sign up for harder trails at the Jeep jamborees next year!
There were two I couldn't goto this year specifically because you needed lockers
Matthew
And if you haven't done so already, another consideration is to take it somewhere close, flex/stuff/droop it on all corners, and actually crawl underneath and check clearances for everything. Exhaust, tranny, crossmember skid, brakelines, disconnected uptravel fender clearance, etc. Anywhere the shafts or tires might contact, or any corner the brakelines are even a little bit too tight. --Do this 'before' you get out on a trail in the boonies--
Unless you mangle a driveshaft on a rock or something, it won't be an immediate failure. Just make a habit of crawling underneath and watching for grease spitting out of the joints. Once it starts spitting, the joint will 'eventually' dry out (could be sooner or later, depending...), start making noise, and then at some point, finally fail. You can repack grease into the joint to make it last longer. Or there are apparently some newer kits to replace the joints, which I wouldn't actually recommend since the exact same thing will just happen to a new rzeppa.
I've never heard of the flexing trick...
I've got a set of medium height ramps, sort of thing you use for changing the oil
Would those do?
Matthew
I have never been under one of the newer 3.6's, so not sure if any of the routing is different - But, flexed auto's have a bad habit of scraping the front shaft on the crossmember skid and even banging it into the corner of the tranny pan. 6spds can jam it up into the exhaust system. Disconnected with not enough bumpstop, you can rip a fender off, or when stuffed and turning the wheel, have the tires contact other components. After lifting mine, I ordered and installed extended brake lines from the same JKF vendor I bought the lift from, then proceeded to go out and rip one of the new 'extended' rear lines off the frame.
Anyway, just a heads-up to go along with the discussion on the need to replace driveshafts. Better to know this kind of stuff ahead of time so you can take precautions if needed.
Try it, but it's probably not big enough to get you the flex you need to really check everything. Some have access to RTI ramps, or forklifts, or lifts at a shop, or tree stumps, or loading ramps behind a store, stuff like that. I use a big ole boulder down at a local park.
