Looking for Teraflex 2.5 with Rancho 9000s experience - JKU
I've searched and read thread after thread. A lot of the reviews I've found are initial thoughts and not long term. The few things I've found that mention long term are complaining about sagging.
I'm about to order a 2.5" Teraflex coil kit with Ranch 9000s. I also purchased a set of AEV control arm brackets that I'll install at the same time to increase ride comfort, avoid any chance of flighty feeling, and to just get it over with.
Does anyone have any long term experience with this setup? My Jeep is a 2013 JKU Sahara. For the time being I plan on retaining the stock bumpers, but Im not ruling out the idea of upgrading those. My jeep is on the highway 90% of the time.
As you add weight you will loose height. I have the Teraflex 2.5 with Bilsteins on my two door, rides great, finally got it out I to the rocks last month. Did great.
Does not give quite as much height as expected due to my added weight.
If your Jeep has the passenger side lean, then it will still have the lean after the swap. To correct it, toss a 1/2in spacer puck on top of the rear passenger side coil.
I have about 15,000 miles on mine now, still rides just as good as the day I put it on.
Hope this helps.
Happy Jeeping.
Hope this helps.
Happy Jeeping.
I don't think I knew or realized this was the KJ system. Cheers to that! (looking at the URL I see your "stage name")
Running same tf springs since 2010 on two different jeeps. No sagging or lean at all and the ride is decent. That's over 100k miles on the springs. Running ranchos shocks for the last 20k or so. I'm using the 4dr springs on my 2 de which netted me 3" in front with stubby bumper no winch. 2" in the rear with a full size 37 and bumper tire carrier combo
