Looking to run 35" tires
Im glad you posted up your pic and talked about your Jeep. Now I can visualize more where I'm headed.
I so want to recreate my old K5. I ran 38.5" tires on 4" of lift, and just gutted the body and wheel wells until nothing rubbed, but the JK just isn't that easy :(
Bumpstops are about rubbing flares but also about bottoming out your shocks, so make sure you won't completely collapse your shocks when you pull all of the flare and liners out of the way.
Changing tires or removing flares isn't going to change anything about the stock suspension. The stock bumps prevent bottoming the stock shocks. I just wonder what the tires are going to rub on now. Control arms? Sway bar? Little brackets that hold up electronics in the engine compartment? Rear wheel well tub? Etc.
I forgot about stock shocks, I swapped mine out early on to longer ones with stock coils.
The setup was for a week until my friend bought them off me :( but with the spacers I didn't touch CA's or sway bars. If you gut the liners then that shouldn't be an issue either. The brackets that hang over top of the flare are possible but unlikely since you'll have the wheels pushed out.
Wheel spacers, bumpstops if you want to play off road before your lift. My personal pic of 35" km2's with wheel spacers on stock rubi wheels and rubi coils.
Attachment 528211
Attachment 528211
I went with the budget lift first and then saved up for 35s, your Jeep will look mean with the lift and stock 32s. If you go with the 35s first you will tear off your fenders, trust me I know. but I can tell you a site on Ebay to find new fender clips to put them back on
Currently I am running 35 inch Duratracs on stock 17 MOABs. Have spacers with a 1.5 Teraflex leveling kit.
I cannot fully flex out.
I am going to be trimming my fenders soon to see if I can flex fully, if not the next thing will be to install bumpstops. I also have the pinch seam trimmed. Hope this helps!
