Looking just to get rid of the rake
So I spent about 30 minutes this morning at my local 4x4 shop this morning with a jack, a level and a measuring tape. After much deliberation, we decided that I need 1.5 inches at the front to get rid of the rake. Now....I could've swore I'd seen 1.5 inch coil spacers but for some reason, I can't find any! I therefore have a couple of questions for you all-knowledgeable in this matter out there in cyberland.
1) Did we measure wrong...and that's why I can only find 1.75" spacers?
2) Can I stack 2x.75" spacers to add up to 1.5"?
3) Is the 1.75" spacer (or any spacer for that matter) going to sag? ... hopefully to 1.5!
I'm running stock 32's and I don't want to go with a full lift, I just want the Jeep to just look right! Any advice you can offer would be greatly appreciated. Thanks all.
Actually I don't have an aftermarket bumper. Everything's stock! I also thought that the rake was about .75-1" but we measured it quite a few times and 1.5" was what looked right and level.
This should do the trick:
http://www.currieenterprises.com/ces...t.aspx?id=2792
Currie 2 1/4" LIFT FRONT LONG TRAVEL LEVELING KIT FOR '07 AND UP JEEP JK WRANGLER FOR UP TO 33" TIRES
NOTE: Sample image only,
actual product may vary.
Part #: CE-9802F
Our Price:$289.95
Description: The long travel leveling kit for all models the 2007 and up Jeep JK Wrangler allows you to raise the front of the JK so that it is even with the back, while at the same time increasing the front suspension travel to 9 1/2". This kit includes 2 1/4" coil spring spacers, lower bumpstop extensions - both finished in semi-gloss black powder coat, adjustable extended sway bar links with heim joints and jam nuts, stainless braided extended brake hose kit, all necessary hardware, and detailed installation instructions. When used in conjuction with the CE-9802R JK rear long travel kit, your vehicle can effectively clear 33" tires. Long travel shocks required - sold seperately. See our Rancho and Walker Evans shock options.
Unit of Measure: Each
Part #: CE-9802F
Our Price:$289.95
You got the JK street rod version!
I am also interested in a 1.5" front spacer kit. I have 3/4" spacers installed now and still have a little rake. I do have the back seat removed, damn thing was heavy when I removed it.
