looking for a good shop in annapolis surrounding area for front drive shaft install
Anybody in the Annapolis area that can recommend any good shops for a front drive shaft install?
Also, will i need front upper control arms to set caster/pinion? I am running front lowers already.
Any opinions or advice is appreciated.
Thank you,
Thank you,
Do you already have the drive shaft? That's an easy driveway type job (if you have an impact wrench). Otherwise, Adrenaline Offroad is a great shop with lots of Jeep experience. They're about 30 miles from you in Burtonsville.
In terms of control arms, you only need uppers or lowers to set the caster. The benefit to adding the other set is that you can bring the wheelbase back to factory (not a big deal unless you have a huge lift). Definitely get an alignment though, so you know your caster is good.
