looking for comments from people who installed 4.56 gears
Old 01-16-2009, 08:33 AM
MJS_Jeep_888's Avatar
Originally Posted by moabjk072d
I have 5:13's in my jeep and I don't have any noise from them, I havent had any problems so far with them and I really like the lower gearing. I have 35's and it seems I am pretty close to what my jeep was geared to stock.
I'll second this - 5.13s with 35" tires, with an auto trans, is a near-perfect combo. If you have a 6-spd, go higher, like 4.88s for 35"s.
Old 01-16-2009, 09:20 AM
troyboy's Avatar
My math shows that if the original tires are say 31.5" then going to a tire that is 35" would be 11% larger.
so 3.73 + 11% = 4.14
4.10 + 11% = 4.55
so why would a person with a 33" or 34" tire want to go 4.88 or higher???
I'm so confused
Old 01-16-2009, 11:49 AM
monte's Avatar
I could use help here, too. If you're driving a 6 speed manual, is it as important to get exactly the right gear ratio? Wouldn't getting gears "close enough" do the job because you control the shift point?
Old 01-16-2009, 04:19 PM
Yoda's Avatar
Originally Posted by troyboy
my math shows that if the original tires are say 31.5" then going to a tire that is 35" would be 11% larger.
So 3.73 + 11% = 4.14
4.10 + 11% = 4.55
I'm so confused
answer: Off-roading!
Old 01-17-2009, 05:32 AM
Yoda's Avatar
Originally Posted by JKDoc
I've spent hours with gear charts trying to decide on the perfect setup. Currie Enterprises has some neat tools on their website if you want to make your own. I'm going with 4.56 gears and 35s. I have the six speed. I don't care if I can't climb the mountains in 6th gear, that is why I have 3rd and 4th and why I ordered the manual. The actual ratios are very close to what you have with stock 4.10 and 32s. I agree the 2.72 transfer ratio can be too high if you are trying to do any rock crawling. I was able to climb Ken's Climb on Fins and Things in Moab with no problem but I think that was the limit. I did stall on a number of ledges. I'm taking care of this with an Atlas 4.3:1 2 speed case. By changing the transfer case I get a crawl ratio lower than a stock Rubi even with the 35 inch tires and still have road ratios that don't have my engine spinning its guts out at 65 mph.
The other reason to stay at 4.56 was the advice I received that the 4.88 pinion for the D30 was getting really small and could be a problem. I guess we have plenty of folks running these. I did not need to.
I agree with you.
Just want to say that some Jeepers like slow (on road) and powerfull ratio. There is no scientific reason. It's a Jeep thing
Old 01-17-2009, 12:52 PM
troyboy's Avatar
Well I ordered my 4.56s today! Still looking for the best place around here to install them tho.
Old 02-12-2012, 05:35 AM
jgerhard's Avatar
Newbie alert: Whats the labor cost for regearing, also, is this 4wd specialist shop or at a normal garage?
Quick Reply: looking for comments from people who installed 4.56 gears
