Long arm kit or coilovers with stock arms
When I get back from deployment Im going to be lifting my 12 but can't decide what to do.
I was dead set on coilovers but coilovers plus a long arm kit is pretty expensive up front so I want to do one or the other then upgrade later.
What would be more beneficial, A long arm kit ( suggestions are welcomed. Was thinking a teraflex elite kit or RK 3.5)
or just getting coilovers with the stock arms for now.
I do more desert driving than rock crawling at the moment but I do like both.
You're going to be limited by your "stock" control arms with great coil overs. When I increased my articulation up front I destroyed the stock upper control arm bushings in one outing. I have Currie adjustable "short arms(stock length)" and articulation is great. I have Terraflex and Bilstein 5100's, not for fast desert driving like the coil overs from EVO On another note if you do fast desert driving with either setup I would think a prorock44 or Teraflex dana 44 housing would be needed to avoid bending the housing on a hard hit(bump, dip, etc...)
2 cents from the Peanut gallery
and also I saw there is 2 different long arm kits for 2.5 inch long arm and 3+ for the elite LCG's. what are the diffrences?
Sponsoring Manufacturer
Are the speed bumps hydraulic or air? was actually considering the pre runner kit but wasnt sure how it would do in the rocks as far as wheel travel goes
I was dead set on coilovers but coilovers plus a long arm kit is pretty expensive up front so I want to do one or the other then upgrade later. What would be more beneficial, A long arm kit ( suggestions are welcomed. Was thinking a teraflex elite kit or RK 3.5)
Are the speed bumps hydraulic or air? was actually considering the pre runner kit but wasnt sure how it would do in the rocks as far as wheel travel goes and also I saw there is 2 different long arm kits for 2.5 inch long arm and 3+ for the elite LCG's. what are the diffrences?
there are many short arm which by default is a bolt on kit....and also many other LA kits like Evo and Full traction, but you can do a google seach and youll see even more brands
Awesome I didn't know the Evo kit was bolt on. I am just into desert driving right now and crawling when I can. I like going fast to but the jeep can't handle that right now.
You guys are very helpful and I will do some more research when I'm at home on the computer.
