lod rear bumper/tire carrier
Old 09-07-2009, 01:44 PM
  #41
Shoup's Avatar
I used carrier bolts just a tad bit longer and I don't need to remove the tire or to get the lift off.
Old 09-07-2009, 05:43 PM
  #42
Muffins's Avatar
Do you have pictures of your setup? I don't see any way to bolt it up between the rack and the tire without removing the tire, but I was able to bolt it between the rack and the Jeep with the tire still on.
Old 09-07-2009, 06:57 PM
  #43
Shoup's Avatar
I will set it up when I get off of work in the morning and take some photos.
Old 09-08-2009, 01:37 PM
  #44
Muffins's Avatar
That would be great, thank you.
Old 09-11-2009, 06:58 PM
  #45
Ryanc's Avatar
Any photos of this, would be interested in to attach the hi lift as well.
Old 09-11-2009, 07:45 PM
  #46
jkrubi09's Avatar
I just got mine finished up tonight. I am runnin 37's. I mounted it at the highest position. I also put a weld bead down each side of the mount onto the frame. When you swing the tire carrier open, it would bow down on the pass side from the weight. I also welded the tire mount on instead of that little bolt they give you. It will shake and rattle if you don't weld it!!
Old 09-12-2009, 04:42 AM
  #47
Ryanc's Avatar
How do we attach the hi lift?
Old 10-27-2009, 06:27 PM
  #48
Ryanc's Avatar
Btw I figured I would post my pictures after the install, forgot to post em up.
I see the quick fist clamps are used, but I dont see how they were attached, the top picture has no holes?
Old 10-27-2009, 06:33 PM
  #49
Shoup's Avatar
Drill small holes and I used self tapping screws I coated in Black RTV to seal the holes.
Old 10-27-2009, 06:39 PM
  #50
Ryanc's Avatar
Thanks, your set up looks sharp.
Quick Reply: lod rear bumper/tire carrier
