lockers Front or Rear?
If you have the money, both.
If you don't, the rear. 90% of the time, you're rear is pushing forward a lot more than the front is pulling.
Get a Detroit and call it a day.
Sponsoring Manufacturer
I concur. I've had times where I broken parts and had to come off of the trail in 2WD. I've had to do it in front only and rear only. Even with lockers, the front doesn't do nearly the work of the rear.
I had them put my lockright in the front when my gears were done, doesn't look hard to do though from what I've read. I really need to pull mine out and install a thicker thrust washer, I'll let you know then, haha.
