lockers
Yes. Any re gear will affect the crawl ratio. By how much is a question for the mathematicians on here. But it depends on your transmission, transfer case and diff gearing.
Front and rear diff ratios should be the same.
Former Vendor
Update on the locker question;does the re-gear choice effect the crawl ratio? Or not enough to consider between 4.56/4.88? Also, how do you know what the front axle gear is?(have D30F/D44R)& if you re-gear is the front done as well?Thank you for the link to lockers 101, gonna get me an edgeamcation on 'um=-O
Easiest way to find out what your stock gear ratio is: call the dealership and provide VIN to service department.
Front & rear are required to have same ratio.
Thanks Mark-great video!:-) I live in Oklahoma; so I'm gonna have to find those mountains. At the min. I would have to put the detroit truetrac LSD on the fr.D30. Might as well-since the front gear change anyways. Thanx again..
Think I'll go for the 4.88 w/ARB Selectable lockers.
You can usually find the d30 truetrac for under $375. Great alternative for these front d30's - sure beats dumping $1500-ish into a d30 arb. (locker, plus the air source, plus the extra install/labor to run the lines and switches).
Ok-now I'm thinkin'**how bout the truetrac on the Frnt.D30 & a E-locker on Rr.D44
Would save some coin & still have GOOD capable rig??
If you don't spend a lot of time with tires in the air, you don't 'need' thousand dollar selectable lockers. But it sounds like you have talked yourself into 'wanting' thousand dollar selectable lockers, so go for it. Electric is a great setup, no added costs for compressors or worries about air lines, and more than likely, the rear 2pin design (compared to arb's 4pin) won't ever be an issue for you. If you think a mounted air compressor would come in handy, spend a little extra and go for arb's. Or, do some reading on the OX locker, since you can run your choice of cable, air, or electric actuation.
Read post 11 in this one. The rest of the thread has good info, but I like the story in post 11 and agree with the statement in bold print.
https://www.jk-forum.com/forums/modi...ffroad-188018/
Thanks for the thread link;that is a good point about the "need" for actual lockers. Do have to consider the type of use for my rig. Would rather have a little more capable & not need it, than wish I had it w/up against the unexpected.:-! Kinda why I was thinking of the last set-up. Thanks for yur help* nthinuf "JK Jedi"B-)
