lockers
#21
Thanks for answering my question. At least someone saw it. As for my other response, I apologize if I am wrong, but ALL of my experience in the past, INCLUDING some Jeeps has shown that a full spool in the front (which is what you are saying the E Locker is engaged) makes steering all but useless. That was my only point about using an LSD instead of a locker. My info could well be outdated as I was working on this stuff perhaps before some of you were born. My original intent was only to try to provide some information...no matter how wrong some think it turned out to be. On anything but harsh rock crawling, I stick to my guns about a good LSD unit.....in the front anyway.
#23
http://www.youtube.com/watch?v=fGJu0ZULs5Q
I have the stock limited slip with traction control int he rear, and an Aussie locker in the front. Even I am shocked at where I can go with this set up.
An Aussie locker is a great unit comparable to a Detroit, is very inexpensive and fairly easy to install for a do it your selfer.
I would go with a locker in the front and save the rear for when the stock unit goes out.
#24
Like my previous response, an Aussie, or Detroit allows for some movement in a turn. A selectable locker you can disengage. With my Aussie locker I notice a difference in steering when 4wd is engaged but at that point I usually dont really need 4wd. the steering is not really that bad, and if you know it you can drive accordingly.
The experience from most off roaders is that LSD are good for on road traction or dirt roads, but for any kind of wheel raising action, lockers are a must.
#25
#26
I'm gonna agree and disagree with you. I'd like to keep it courteous as you're in my neck of the woods over here and I hope to meet you on the trail someday.
First I see you're driving a Rubi which says you have no experience with the new Jeep LSD. Combined with the Brake Lock, it's very effective. I frequently challenge my riding partners with their TJ Rubi's and can conquer everything they can with just my rear limited slip. It pisses them off to see me go up after waiting for them to stop and switch on their lockers. This did not used to be the case with the TJ LSD so you are forgiven for giving old advice, but don't disrespect the the JK LSD until you've actually experienced it. (BTW I do have a front ARB/D44/Superior gears and axles on order.)
Now as far as wasting someone's time with an opinion and no facts to back it up? You're spot on Bud
It's been my experience many times over that the best bang for the buck is an Aussie locker up front. It's transparent in 2wd, and incredibly effective in 4wd. All for a couple hundred bucks and a couple hours. Sure, selectables are the way to go if you have the cash, but a JK with aggressive tires and a lunchbox locker is a pretty formidable machine.
Redneck Jeep, sorry, clearly I stepped on your toes. Diplomacy just ain't my strong suit...
#27
Back to the topic...according to the Northridge site, the aussie locker "hasn't been tested on the JK". So, I am assuming from the folks sayin they have them that they fit and work?
#28
