Lockers?
#21
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
My choice would be rear if you only do one. It seems that most of the time you need a locker, you will be going uphill. This puts a lot more of the vehicle weight on the rear axle, and a lot less on the front, right? So even locked, the front may not have enough weight on it to gain traction. And then there is the consideration of a d30 up front and a d44 in back. I would much rather lock a 44 than a 30.
#22
So, If I understand this correctly, in 4 wheel drive, you could potentially only have one wheel on each axle getting power, and it's the one with the least resistance so potentially the ones that are slipping or in the air? So with out lsd or lockers you could just be 2wd even in 4wd.
#23
#24
Originally Posted by nthinuf
The JK has some electronic goodies that will apply brake pressure in that instance, which will give enough resistance to transfer a little power to the tire that does have traction. Better than just open diffs, but not as good as a limited slip.
#25
BLD - brake lock differential
There is a link in this one that will take you to an explanation on the chrysler website.
https://www.jk-forum.com/forums/show...tial-Operation
#26
Based on my reading and research this afternoon with all your help, I think LSD seems like it would be best for most situations except the most difficult off road situations which even then would be better than an open diff?
#27
Yes. Lockers are really just for folks who off-road a fair amount, and want to be able to handle challenging obstacles. If you're not off-roading fairly frequently and the $2000 for a pair of selectable lockers is money that you'd rather use elesewhere, lockers are probably not a wise spot to spend your money.
#28
Sponsoring Manufacturer
#29
Originally Posted by Dynatrac
This is correct except an LSD will act like an open diff if 1 tire has zero traction. You may be able to apply some brake and get some traction to the tire on the ground but that won't work in every case. A true locker is your best bet.
#30
Well, that is something to think about? I wonder if a lsd up front and a locker in back would be best for me? I would have alot more capability on and off road compared to stock. It's funny the more you get into all this, the more I realize I shoulda just bought the rubicon!
If I was living in the north country still that is how I would set up
