Locker on Rear 3:21 Diff
Has anyone bothered to install a locker on their standard DANA 44 / 3:21 ratio differential? It is obviously not a setup for "hardcore" offroading. I would just like the option there for "just in case" to provide a bit more of a boot in the rearend so to speak. Thanks in advance for any info. Take care... Mike
![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
stupid 10 character rule
Thanks guys but I generally use her for a DD and get 24 to 25 MPG (ACTUAL not Displayed). I've checked these calculations over the period of 10 months and 15,000 miles and have had others check my math as well. Any trail running I do she handles just fine with Low Range and proper tranny gear selection. I don't do the "hard-core" off road driving that a lot of you do. If I need to get into a particularly "nasty" terrain I will simply use the ATV. SARA (my Jeep) tows it just fine.
The idea behind the locker hooked -up to the 3:21 diff is to simply allow her to get a little better footing should the need arise. Thanks again guys... Take care... Mike
Obviously you can do it. BUT seriously atleast put 4:10's in it unless your leaving the 3:21's for fuel mileage. There are alot of guys selling their stock gears on here and if your in there and paying for the locker install you might as well do the gears.
Im right behind you. Lockers and gears are hopefully my next mod.
