LineX pros/cons
Old 04-15-2016, 05:40 AM
  #51
pxb006's Avatar
Just had mine sprayed with Line-X and it turned out fantastic.
Stripping it down was not nearly as bad as I was expecting. One tip...when removing the heat shield, use a oscilating multi-tool with a toothed blade to get the bulk of it out. Then lay a towel on it and pour some lacquer thinner on it. Let it soak for a minute then hit it with a putty knife. Comes right off.
Old 04-26-2016, 09:05 AM
  #52
Scrappi's Avatar
Those of you who had it done... Did you put all your plastic trim back in or leave it out?
Any pics?
TIA
Old 04-26-2016, 09:25 AM
  #53
doc5339's Avatar
Originally Posted by Scrappi
Those of you who had it done... Did you put all your plastic trim back in or leave it out? Any pics? TIA
Line-X put mine back on and installed wire loom around the wires bundles that ran under the carpet.
Line-X is worth the money.
Old 04-26-2016, 09:31 AM
  #54
14Sport's Avatar
Same here. Put all the trim back in. It hides the wires.
Old 04-26-2016, 10:11 AM
  #55
Scrappi's Avatar
Gotcha. Thanks
Quick Reply: LineX pros/cons
