Lincolnlock?
Lincolnlock?
My spider gears are self destucting. I know it isnt one wheel burnouts or the mighty torque of the 3.8. Any options? Its an open 44 with 4.88s turning 35s.
I notice you have upgraded to 4.88s. Was it going through spider gears before that? I had to change my fluid after a 500 mile break-in period. Could metal shavings from the ring and pinion be getting in the spider gears?
I'll admit I'm grasping at straws, but it's all I can think of.
Sounds like you maybe have a bad carrier. not sure of your warranty status but you might be able to get it fixed under warranty. If not you can probably pick up another carrier at a junkyard cheap and do a rebuild. Sadley when spider gears start going it usually means the pin is wearing as well and new spiders/bearings aren't going to help much. Shouldn't be overly expensive if you have to pay, around $500 (I had a similar problem on the 9inch rear on my Bronco). Maybe consider upgrading to a locker since you have to tear the rear apart anyway??
23000 miles on the Jeep and first owner, I might get warranty help but didnt want to put more bad parts in it. The pin does rock in the carrier too, looks like a rare problem for us but I would rather go back with a truetrac or something comparable? Guessing the lincoln locker would finish off the carrier along with everything around it before the after market catches up.
