Limited slip diffs?
Limited slip diffs?
Since my JK is a DD it seems like I should stick with LSD's. The rear is the stock trac-lok. front is open. Is the detroit true-trak a good option for the front?
should i leave the stock rear alone until i have a problem with it?
I have installed Truetrac's FR & RR and they are simply the best for my needs. I certainly don't hit the rock gardens and never intend to, just trails & forest roads, etc... Man, if you do plan on getting the FR done get the RR done too because the factory LSD is not good at all and in time will render useless. It's my advice, if you want to save some coin, to get them installed the same time you regear if that's in your future.
Sponsoring Manufacturer
The TT is your best option. For off road use a gear driven LSD (like the TT) is the only real LSD option we should consider. Clutch driven LSDs wear out very fast when a tire is lifted and spun. With a gear driven unit like the TT, free spinning the tire doesn't cause any damage and you don't lose any LSD function.
Years back I had Detroit Electracs in both ends of my Jeep. The Electrac was an electric selectable built by Tractech (the builder of the Detroit Locker before Eaton bought the Co.). It was TT based then switched to full lock. On one run where we had a lot of snow, mud and steep hills with wet roots the TT really showed its worth. I had numerous friends on the run that had ARBs. All day long I could hear them turning on and off their lockers. Never once that day did I use the lockers. I used only the TT LSD function the entire day. What that day showed me, very clearly, is that when most people hit the locker (ARB or similar) it's not because they need a locker, it's because they need something better than open.
For a moderate wheeler or a DD, the TT is a great option.
Mine was supposed to installed yesterday. The local 4wdparts store called and told me they wore out several drill bits, trying to enlarge the ring gear bolt holes. Even tried, harden bits. They have enlarged carrier ring gear bolt holes before with no problem but, in that maybe Eaton hard this carrier different? Which in the end, might be good for me!
They will have to wait until Monday to call Eaton to find out what to do! They said will probaly take to a machine shop to have drilled out?
I would replace the rear factory lsd if it was me.
so if I only could pay for front or back right now I would get the front right? or is the back one that bad that it would be better to get the rear?
I'd go ahead w/the front as u planned, no prob there man. As you read on along the forum you'll notice that many here will say, plan ahead...meaning if you go ahead and get bigger tires it's possible you may need to regear to accommodate...thats the best time to get everything installed so you don't have to waste money twice on labor. Happy Jeepin'!!!!
