Light pod help
Light pod help
Hello! I need a little help. I just installed my light bar and wired it directly to the negative and positive terminals on the battery. I am doing the pod lights now and was wondering if I can do the same with those and stack them on top of each other or do I have to run the power wire to one of the three other terminals off to the side
At the very least, I'd be running each of those accessories to a relay, and then pulling power from the battery with an inline fuse for each. I would not be wiring those directly to the battery.
XJRefugee (03-02-2023)
Yes you can stack them as far as the connection at the battery is concerned, but as resharp said above, hopefully you are using a harness with a relay and fuse, not just wiring directly to the battery with a switch.
I'll be doing this soon hopefully, I have some pods in place just waiting on a light bar, but both will have fuses and relays from the harnesses I'm using for the wiring.
