Lifting a 2012 JKU Rubicon
JK-Forum Founder
1st is there any particular reason to NOT LIFT a 2012 JKU Rubicon?
2nd what is needed to do it RIGHT
JK-Forum Founder
well, with just 2.5" of lift, you'll want to make sure that you either get a kit that comes with shocks that are short enough to prevent your front drive shaft from tearing it's slip shaft boot on the exhaust cross over - OR, make sure to install either exhaust spacers or cross over relocation and for good measure, install a new front drive shaft as well. most 2.5" kits do not come with an adjustable front track bar and, while it's not "needed", having one will allow you to recenter your front axle. aside from that, you're good to go.
JK-Forum Founder
of course. a good 2.5" kit will come with new longer rear sway bar links and that will allow you to install the factory rear links (which are much longer than the factory fronts) up front. with that, you'd be good to go.
simple terms: call Dave or Sean at northridge and order a teraflex 2.5 inch spacer lift or the coil lift depending on what you plan to use your jeep for. They can help you with anything.
