Lifted JK front steering component Geometry
Resharp001,
I know I'm still learning this stuff but look at my photos that I took of my front spring column. Aren't these the bump stops( they are attached to the top? Are they adequate for flipping drag link?
Again thanks for noticing and your input is appreciated.
Marc
Marc
That is just a foam. Thing that compresses to nothing. A bumpstop will be a hard piece like this -
Oh!!! Wow. Ok I didn't know.
Thanks again for noticing. Is it a big job to lift the front chassis and drop axle down enough to get coil out and put this in?
Marc
Marc
If you're in between lift kits they you can cheat (temporarily only) and squeeze hockey pucks in there with double sided tape. They really should be bolted to the pad and you can get away with a nyloc nut on the bottom. I've toyed with the idea of tapping the pad but I don't know if there's enough metal there to make it work.
There is. Years ago I used hockey pucks, which are perfectly fine btw, and eventually put an actual bumpstop there. When I swapped em I tapped the hole for the screw the new stop used and never had an issue.
karls10jk (11-11-2019)
Will this work for my lower bump stop or is this the wrong kind of part ( since it says extension). Having a hard time finding 3" bump stops
Marc
Marc
Those are fine. I've actually had a set of those in my garage forever that I just sent along with axles I sold. I have EVO 3" bumps and would say the EVOs are a slightly larger diameter vs. the JKS, but those would work fine. Stacking 3 hockey pucks, drilling through em all, and using some all-thread and ny-lock nuts and washers to hold it all in place is probably <$20 for comparison. All you're doing is providing some surface for that little rubber/foamy thing to hit on before the actual spring perch itself.
Here's a short yourtube video of the install. Note the previous comments on tapping holes for the bolts - shown in the first few seconds of the video. And there are many other writeups and longer vids if you look around.
If you don't want to drill and tap, or tape or gorilla glue hockey pucks or whatever, you could look at replacing the upper stops instead. (Teraflex is a popular choice, haven't really followed any other designs for those)
