lift upgrade question?? help
Old 09-11-2012 | 09:28 PM
2010islander's Avatar
Default lift upgrade question?? help
I have a 2010 2dr with. 3.5 rc serries 2 lift. I now want to upgrade to better springs 4"-4.5" and either bilstein 5160s or fox shocks to get a better ride. And some more flex off-road. What will I Need to upgrade? And the best coil to go with
What I have.
Skyjacker brake lines good for 7" lift
Track bar brackets front and rear
Fixed front lower control arms
Rear coil spring correction plates
35" toyo mts
Old 09-14-2012 | 09:17 PM
Bump! None with insight??
Old 09-14-2012 | 09:36 PM
JKingAround's Avatar
Get a rubicon express 4 1/2 super-flex, fox shocks and driveshaft or shafts and sell your lift
Old 09-14-2012 | 09:52 PM
afpilot82's Avatar
Veteran: Air ForceJK-Forum Ambassador
Evo coils and some adjustable control arms.
Old 09-14-2012 | 09:54 PM
Tricky0s's Avatar
Yeah with 4 inches of lift you are definitely going to need new driveshafts
Old 09-17-2012 | 09:18 PM
Thanks for the responses I'm looking for better onroad performance too you think the evo coils will give me that? And what kind of drive shaft are good without overkill?
Old 09-17-2012 | 10:12 PM
big dr's Avatar
ok,, from personal experience. my buddy has an 08 rubicon 4 dr. he has the taller old man emu springs( i think 4"), he has a 1" spacer, and he went with the fox 2.0 8 position adjustable shocks. before this, he had the OME 2.5- 3" springs with OME shocks. after we installed the taller springs with the fox shocks,,,,,,,, un be lievable!!! he is so fast on some of the rough fire roads in big bear,, the guys with lesser shocks cant keep up. he is a firm believer in the OME springs,,, they flex a lot and do it well. he got a great deal on the fox shocks ($1,000) ( aprox) and said they were probably the best money he has ever spent on his jeep!! this is a guy running 37" km2's, fender flares, hansen bumpers, on board air, teraflex arms, winch, lights, and bunches of other stuff. he put a lot into this jeep , and says the fox shocks are the best investment. my suggestion,,,, OME with fox shocks! best of luck!
Old 09-17-2012 | 10:14 PM
big dr's Avatar
by the way,,, on road,,, amazing with the shocks dialed in!! rides like a cadi.
Quick Reply: lift upgrade question?? help
