lift trouble
#31
must be everyone be an asshole day
Q: What size lift do I need to get in order to fit 35" Tires?
Q: What size lift do I need to get in order to fit 37" Tires?
Q: What are all the components that I will need with a 3" lift?
Q: What are all the components that I will need with a 4" lift?
Q: Are there any write-ups on how to install a lift on my Jeep JK Wrangler?
Q: What is Caster? How much do I need?
Q: I just installed a lift on my JK. Do I need an alignment?
Q: What back spacing will I need on my wheels in order to clear 12.50 wide tires?
Q: What gear ratio should I be running with 35" tires?
Q: Are new driveshafts needed after installing a lift?
Q: Is there a good chart that I can refference to help me determine what gear ratio I should have installed based on the tire size I am running and the RPM's that I hope to be running?
#32
You are right about the cambolts though. They should be destroyed forever!
#33
