Lift tool check list
I just got the last box for my lift and will be installing it this weekend - what hand tools do you wish you had to make it easier?
Thanks Clayton Offroad for shipping out so quick and allowing me to call numerous times with questions!
What I have so far:
- Hydraulic jack
- jack stands - 2, max height about 20" thinking about getting 2 more
- 1/2" impact wrench and metric impact socket set
- 1/2" inch socket set
- magnetic angle finder
- various open end wrenched, screwdrivers
- after seeing the size of the nut on the control arms - need larger open end wrenches
- small wheel grinder
- drill and tap - required to install lower bump stop
??? any other suggestions?
What I have so far:
- Hydraulic jack
Torque wrench. A good one. You may want a breaker bar too.
You also may or may not need a coil compressor. You can "rent" one from Autozone, etc.
Also, how complete is your socket set?
Jason
Jason
pretty complete - got one for father's day, has metric and standard 1/2", 1/4" full range of sizes from what I can tell. good call on the torque wrench
no seize for? what about lock-tite?
Another set of hands is what helped me the most! Find a friend who is at or above your level of wrenching and feed them and promise them beer after you are done!
