Lift Suggestions - $1400 budget
Former Vendor
Good luck with the lift and glad you're looking at our system!!
You wont be disappointed if you go with the Max Travel 2.5" System. It will clear your tires, flex like a champ, and drive down the highway great. Also, if you plan on upgrading in the future you can always adjust the arms to dial in your caster and pinion.
Few questions!
I currently have a 2" coil spacer on my stock sport suspension. Other than flex/ride quality, will there be a huge noticeable difference as far as physical ride height with the 2.5" RK lift?
Also, is the only difference between the 2.5" RK Max Travel and "2.5" RK Flex System the rear control arms?
Former Vendor
Few questions!
You are correct, Flex only includes the front lower control arms. However, the flex system also does not include the rear brake lines or the rear swaybars. Either kit will do what you're looking for and ensure your vehicle tracks well down the road. The max travel is more complete, performs better, allows for more adjustability, and because of that it will also cost more.
RK
Recently did the RK 2.5 Flex with 35" tires. Very happy with ride, etc. I ended up right around 3" of lift running a metal front bumper and Ace Rock Sliders. I think 3.5" is a bit much for 35s, and it opens you up to so many more potential issues.
I'm gonna derail the Rock Krawler love fest and tell you to look at Metalcloak. Better ride, no guessing on shocks, a legit lifetime no questions asked warranty (which transfer to a new buyer if you sell it), and you'll be happy when your joints are not seized after a winter. While some may not like the color, the gold coating on the MetalCloak arms is actually zinc chromate. Chemically, amazing stuff. It essentially gives its life to stop rust. The Duroflex joints will ride better, no questions asked. Obviously, since they are not solid joints.
Don't get caught up in all the BS about flex. The stock arms will flex well beyond any shock you will run.
No offense to the AEV people, but AEV took stock level quality stuff, matched it up for you, slightly tuned it, and then multiplied the cost by 4. Go get some higher spring rate coils off a heavy JKU and you'll save $1000.
My JKU will be paid off after next month....no more monthly payments.
![Clap](https://www.jk-forum.com/forums/images/smilies/clap2.gif)
AEV is already crossed off my list.
Which Metalcloak lift would you suggest? Like I said $1400 is my budget and I know Metalcloak runs more expensive.
And then any of the 3 shocks they offer (ARB, RockSport, Fox). If you are on a budget, go with the RockSport. I doubt they are any less quality than the ARBs.
Former Vendor
As for springs. I'll put our triple rate up against anyone's linear rate, dual rate, or progressive rate. A dual rate spring is a linear spring with dead zone. That dead zone ensure the spring doesn't fall out. So you're taking old tech and making sure it doesn't fall out. Progressive rate coils and multi - functional rate coils offer an improvement in ride quality and stability. They still have a dead zone to ensure the coil doesn't fall out but they are also working to improve overall performance. On road it increases performance with transitions to decrease sway and roll. Off road it improves stability when the coil is at full stuff (bowing) and the coil is losing it's rate.
Good luck with the purchase but don't get us started on springs or snow. . . we know both very well.
RK
