Which Lift Should I Buy?
Rough Country 3.25" $380
Front: 2.5" lifted progressive rate coil springs and 0.75" coil spacers, and brake line brackets.
Rear: 2.5" lifted progressive rate coil springs, 0.75" coil spacers, track bar bracket, sway-bar links, and brake line brackets.
Shocks: (4) High Performance 2.2 series shocks
Full Traction 3" $600
Kit includes: Front and rear springs, front track bar bracket, rear track bar bracket, front & rear sway bar links, billet aluminum bump stop extensions, brake line extension brackets, and complete detailed instructions
TeraFlex 3" $725
TeraFlex 3" $725
Just
i just received my TF 3" a few days ago. very complete lift. worth getting. i got mine with shocks and 4 control arms. very nice kit. i would recomend. TF will give you the best CS. oh yea the control arms are as thick as a coke can!
Whats youre budget? what do you want to achieve? are you going wheeling or mall cruising?
There are many good choices out there, with lots of options, do some research on here (jk forum) you'll get ALOT of ideas what is best...
Teraflex, BDS, Rubicon, to name just a few.... all have good warranties, all are good quality, all have good customer service.
Buy a kit to fit you're need, and budget, and know that you can always upgrade when $$$ becomes available, with any of these companies.
Thanks for the input guys. I guess I'm torn b/c the more expensive of the 3 don't come with shocks and its more money I'll be spending on top of they're already high price.
I'm not looking to be a full on rock crawler. I'm going to new mexico in october for a back packing trip but would like to be able to clear a few more obstacles. I've never had much problems stock, but I'd like to be a little more prepared for the unexpected.
My .02 cents
I agree w/ all the other comments I would go w/ the Teraflex as well. I have ordered my lift from David @ Northridge which is essentially the OME HD however, I substituted the 2" OME HD springs for 3" Teraflex.
Just keep in mind that you get what you pay for. I want to make sure my system will provide the best ride and handling. It is my daily driver.
