Lift with Rubicon Electronic Disconnects
Old 07-10-2013 | 05:20 AM
SabrToothSqrl's Avatar
Default rears
my BDS 3" kit came with spacers that effectively lowered the rear sway bar 1" or so.
I think I'd rather have longer sway bar links.
Why do they do this, and wouldn't longer sway bar links have been cheaper? (for them)?
Old 05-19-2014 | 08:18 PM
dmalquist's Avatar
Default Manually disconnect?
Originally Posted by Smashboogie 4x4
If you do a small leveling kit then longer drop links are not really needed. The Teraflex Budget boost typically moves the rear drop links to the front and replaces with longer rear links.
You will not harm the E-disco by installing a lift. Even though you have the E-disco we still recommend to manually disconnect. We recommend this for a few reasons. Number one being that it is possible to over rotate the sway bar and when you put weight back down on the tire it will bend the link. Number two is because the link and sway bar could limit your down travel.
I have a 2009 Rubicon and do not see how to manually disconnect the sway bar. I am concern about this issue as I want to have a 2.5 lift on my jeep. What should I do to not have trouble with the disconnect?
Old 09-18-2014 | 02:10 PM
kevinlee's Avatar
Has any one tried a limiting strap of some kind to keep the sway bar from over rotating while disconnected?
Old 09-18-2014 | 07:00 PM
CaptainGeech's Avatar
Do yourself a favor and always manually disconnect. This is why I know.
Old 09-19-2014 | 09:23 AM
BellDiver's Avatar
A picture worth a 1000 words.
I'm in same situation. I have not tried this yet, don't even know if it works with a 2.5 lift or not.
EVO: Suspension / Steering, NoLimits Manual Rubicon Swaybar Disconnect
Old 09-19-2014 | 09:29 AM
That Evo thing won't save your Swaybar links though if the swaybar flips to the other side of the draglink.
Old 09-19-2014 | 10:16 AM
kevinlee's Avatar
Talked to my service guy this am (I. have a life time warranty so am havin them do the install). He is. Ordering the Mopar sway bar links for 2-3" lifted rubicons they are made for the e-disco. - am still gonna go the quick disconnect route with them. Then I can e-disco the trails n stuff here and quick disco any trails where I will really be flexing just I case.
Old 09-19-2014 | 03:24 PM
BellDiver's Avatar
So then it is possible to keep edisco and have a qd and have longer links and reduce risk of damage?
Sent from my phone. Please excuse the brevity, spelling and punctuation.
Old 09-19-2014 | 03:59 PM
kevinlee's Avatar
That is what the guy from Northridge and the guy from RockKrawler both suggested. They both said use the edisco for easy trails and unpaved roads and disconnect for serious trails. This works for me since my part of Ohio kinda lacks serious trails. Lol. The service guy at my dealership says the Mopar links are all you need but he drives a Toyota not sure if I trust him lmao. They do sell the mopar links on Quadratec for 109$
Old 09-19-2014 | 05:02 PM
No, absolutely. Different conditions call for different approaches.
In my case I decided to stay connected after some razzing from other Rubicon owners. I went down a very short descent at an angle and heard grinding when I got to the bottom. Swaybar link was hung up on my virgin Synergy draglink I had just installed and the swaybar link tab on the axle was bent in addition to my picture above.
If you're anywhere close to flexing out, just don't make the same mistake I did.
Quick Reply: Lift with Rubicon Electronic Disconnects
