Lift question
Old 03-16-2020 | 06:48 PM
  #21
nthinuf's Avatar
Originally Posted by The Rookie
hmmmm. So when I look up the numbers on the springs it comes up Rugged ridge. Now I’m confused.
No other components seem to match that 4" Rugged Ridge kit, so could be as simple as the previous owner had a lift but wanted to go taller and swapped coils.
Going forward: Keep an eye on those Cam Bolts, they have been known to slip. Keep an eye on that front driveshaft, watch for grease spitting out of the joint at the tcase. And if you decide to go for a flip/hi steer, pay attention to keeping the trackbar and draglink parallel to each other. (when you move the draglink to the top of the knuckle, the trackbar needs to be moved up with a bracket to match...)
Old 03-17-2020 | 09:12 AM
  #22
The Rookie's Avatar
will do. Thank you to ALL for your input.
Old 03-17-2020 | 05:58 PM
  #23
Carylab's Avatar
35's will fit fine right now. (what is the backspacing on your rims?) With flat flares, 37's would look better to fill some of that wheel well space.
Does this look like it might be the kit?
https://ruggedridge.com/4-inch-lift-...ription_tabbed
http://www.ruggedridge.com/instructions/18401.60.pdf
No idea of the quality, but a few items that jump out are:
Cam Bolt Kit - (it comes with a set of front and rear fixed control arms, were the cams installed also?)
Front Trackbar Drop Bracket - (which requires a Drop Pitman Arm that, as indicated in the description, is very helpfully not included in the kit...) Verify whether these are installed.
6” lift w/37’s and flat flares
Old 03-18-2020 | 07:38 PM
  #24
The Rookie's Avatar
what lift and what flares are those?
Old 03-18-2020 | 08:48 PM
  #25
TheDirtman's Avatar
Bushwacker flares, looks like a RC lift but hard to tell from the distance. Those wheels and grill leave a lot to be desired.
Old 03-19-2020 | 03:52 AM
  #26
Carylab's Avatar
bushwacker flat flares and Rough Country lift. I do zero off-roading. This is just a weekend toy for me to pull the top off and ride around town when the weather is good.
Old 03-19-2020 | 03:55 AM
  #27
Carylab's Avatar
To each his own man. I get more questions and compliments about that grille than anything else. I bought that Jeep completely stock one month ago and spent the last 3 weeks building it. Have turned down 2 offers to sell it already.
Old 03-20-2020 | 09:44 AM
  #28
barongan's Avatar
I use Smittybilt, so far so good
