lift question
Old 12-29-2011 | 09:54 PM
Abond167's Avatar
Default lift question
couldnt find the answer to this elsewhere on the forum.. if i wanted to run 33" duratracs on my 4dr JK, would a 2" leveling lift provide enough clearance to do so?
Old 12-29-2011 | 10:01 PM
Hodge7467's Avatar
Yes and either new wheels or spacers.
Old 12-29-2011 | 10:16 PM
TXBeachJK's Avatar
I'm running 33s with no lift but have after market wheels. No rubbing on road, very slight rubbing when offroad and sway bar still connected, rubbing like crazy with sway bar disconnected.
Old 12-29-2011 | 10:23 PM
armycop's Avatar
Here is mine with 2" Rusty's Spacers, 33x12.50x15 Duratracs...
Old 12-29-2011 | 11:10 PM
Sniper77's Avatar
Yes, I am running the skyjacker 2" coil spacer lift with all stock suspension components and I am clearing 33x12.50x15 x3.75bs mud tracks on procomp 98 wheels with no rubbing on calipers,fender wells,fenders, or suspension. If you are going to run 33's on stock rims you will have to run 1.5" wheel spacers at all four corners or you will rub.
Old 12-30-2011 | 05:54 AM
Remington19's Avatar
I run 33's Duratracs with no lift, stock rims but did have some rub so I added wheel spacers.
Old 12-30-2011 | 08:49 AM
Abond167's Avatar
sorry, meant to also include that i want to run 15 x 8 MB72's, but from what everyone has been saying, it looks like i should have no problem.
Old 12-30-2011 | 09:58 AM
Wandell's Avatar
Right. You will be fine.
Quick Reply: lift question
