Lift Question
Old 12-13-2011 | 06:59 AM
prowler9's Avatar
Default Lift Question
I am picking up a 2.5 inch teraflex coil lift with shocks today and was wondering since I have the extra weight on the front (RR XHD bumper w/stinger and 12000 lb winch) will I need an extra spacer to level out the front or will the coils be enough
Thanks for any help on this and sorry if this was already answered.
Old 12-13-2011 | 07:03 AM
wayoflife's Avatar
JK-Forum Founder
while you may find that you'll want to add spacers to help eliminate any sag you might have, i would recommend that you wait on installing a set until after you know for sure if you have a sag, one that's enough to matter to you and if so, how much. if you add spacers now, you may find that they add too much or even not enough. take one step at a time and that way you'll know for sure what you want and need.
Old 12-13-2011 | 07:07 AM
jeep2007's Avatar
x2. You may find it level and if it sags in time then add a spacer. Very easy to add them even once the lift is installed.
prowler9's Avatar
Thank you very much for your reply! I will install and see how it goes..
