Lift Problem Need Help!!
Yesterday I installed a 2.5" teraflex coil lift and when I was driving home my ESP/BAS light and the ESP/TCS light came on and stayed on. Is that normal? What can I do to get them to turn off (maybe a rear adj. track bar)? thanks for the help.
Just a little off freaks out the computer
Q: How do I recenter my steering wheel?
A: To re-center your steering wheel, use a 15mm wrench to loosen the 2 nuts on the turnbuckle on your drag link as shown in the pic below. Then, rotate the turnbuckle clockwise or counter clockwise as needed while a friend watches the steering wheel (or you periodically check on it yourself) go back to center. Once re-centered, secure the nuts and take it for a drive to check your steering wheel. This may take a few tries to get it on 100% but that’s all there is to it.
Here is the full DIY Alignment write-up. Good info to browse through.
http://project-jk.com/jeep-jk-write-...-end-alignment
I recentered the steering wheel atleast it looked good to me but the light stayed on do i have to drive it a long distance for the computer to sense it? could something else cause this problem?
Good Luck
